EX I 1994 Rhythmic knock at the front of the car
: 2018-12-17, 17:22
autor: gery73
Gentlemen, please help ...
I have an ExI from 1994. I have restored it to the factory condition, but I can not get rid of one problem. When adding and subtracting gas, you can hear a rhythmic knock at the front of the car. (identical when dealing with broken wheel bearings. You have ideas what it can be?
I replaced everything in the suspension: left and right wheel bearings, suspension bolts, crosses, undressed rear axle.
Surely there will be someone with more experience and tell me what else to check.
Regards Gerard
Re: EX I 1994 Rhythmic knock at the front of the car
: 2018-12-17, 19:04
autor: Kamyk.
From the left or from the right ?
: 2019-01-05, 13:37
autor: gery73
Central, it`s sounds like a reduser. If I lift a car and start turn rear tire I feal rolling resistance if I unhitch the shaft everything is ok.
