geos1 - obecny rozmiar moich kół to 255 /70 R16
Daniel - potestowałem trochę dzisiaj autko i podczas wyprzedzania lub nagłego przyspieszania (jak to Wojtek mówi but) zapala się kontrolka "Check Engine", poczym gaśnie. - na gazie
PS
RockAuto - $53.99 / dostawa $36.70 + cło-
http://www.rockauto.com/catalog/raframecatalog.php
MOTORCRAFT Part # DY734 {#F39Z9F472AFFV}
F39F-9F472BB; 2 required per vehicle; Front
Heated Oxygen Sensor (HO2S)
The EEC-IV systems use only one heated oxygen sensor (HO2S) (9F472) for engine control. The EEC-V system uses two HO2Ss.
One HO2S is used for engine control.
The second HO2S is used for catalyst monitoring.
The heated oxygen sensor reacts with the oxygen in the exhaust gases and generate a voltage based on this reaction. A low voltage indicates too much oxygen or a lean condition. A high voltage indicates not enough oxygen or a rich condition. The heated oxygen sensors are located in the exhaust pipes below the exhaust manifolds.
Ostatnio zmieniony 2008-05-10, 22:07 przez
mika, łącznie zmieniany 7 razy.
