No to, ze tak powiem sprawa prostsza
Jesli przyczyna niepalenia jest tylko rozprogramowany pilot to ponizsza procedura powinna zadzialac dla vim 150 ( to "stara" wersja immo dla ex 95-96) i w efekcie pilot lub piloty powinny sie zaprogramowac na nowo.
(niestety tylko po angielsku).
WYMIENCIE JEDNAK NA PROBE TO NOWA BATERIE I DAJCIE STARA.
Programming the Remote Control - '95 MY Vehicles
l Unlock the vehicle using the remote control (turn off all electrical consumers, e.g. the radio).
Note:
If the following steps are not completed within two minutes, the immobilisation system will activate itself. To make it easier to carry out this step, lock the vehicle from inside, then unlock it again, and set the ignition key to RUN.
l Put the ignition key into the ignition lock and turn it to RUN.
l The immobilisation system warning lamp will come on for about three seconds and then go out.
Note:
If the following step is not carried out without delay, it is likely that the time dependent sequence of the operations will be interrupted at this stage.
l Wait until the immobilization system warning lamp goes out, then switch the ignition to OFF and then immediately back to RUN. Repeat this ten more times.
Note:
It is important NOT to turn the ignition back to the OFF position after the eleventh cycle.
l On the eleventh repeat cycle the immobilization system switches into programming mode. The warning lamp flashes in one second intervals.
l Within 20 seconds, program all the remote control units (including old ones) by pressing the send button on each. For each one, press the send button until the immobilization system warning lamp begins to flash faster.
l Finish the programming sequence by switching the ignition to OFF.
[ Dodano: 2007-09-14, 23:42 ]
______
powyzsze to jest procedura "11" razy - inna wiec od tej "8"
