"Bordeaux Automatic Transmission's first product was the C3 3-speed automatic transmission for the Ford Pinto. The C3 design was succeeded by the A4LD 4-speed automatic during the mid-1980s and was in turn succeeded by the 4R44 and 4R55 4-speed automatics during the mid-1990s. The Bordeaux Automatic Transmission Plant's current products are the 5R44 and 5R55 5-speed automatic transmissions."
"A4LD
Used in 1985-94 in many Ford products.
This is a partially computer controlled rear wheel drive transmission.
Top cooler line is the cooler return line.
Band adjustments:
O/D = 1½ turns
Intermediate = 1½ turns
Reverse = Not adjustable
Gear Ratios:
2.47:1 1st gear
1.47:1 2nd gear
1.00:1 3rd gear
0.75:1 4th gear
2.1:1 reverse
"The A4LD was the first Ford transmission to use an EEC-controlled torque converter lock-up clutch and later became the first to use electronic shift control (via a 3-4 shift solenoid). The French-built A4LD was created by adding overdrive to the front of the C-3 three-speed unit. The A4ld has a 2.47 first gear and a 0.75 overdrive."
"5R44E/5R55E
Used 1997-up in many Ford products with    4.0 L engines and 2001-up with other engines.
This is a computer controlled rear wheel drive transmission.
Gear Ratios:
2.47:1 1st gear
1.86:1 2nd gear
1.47:1 3rd gear
1.00:1 4th gear
.75:1 5th gear
2.10:1 reverse
http://www.charlietranny.com/Ford.htm
http://www.therangerstation.com/tech_library/a4ld.html
Pamiętam jak mieliśmy 95 OHV i licząc były 4 biegi zawsze. Powyżej 150 już nie redukował. Mój przy 160 nawet jak się depnie to zredukuje jeszcze.
							Ostatnio zmieniony 2015-01-24, 21:30 przez
Kamyk., łącznie zmieniany 3 razy.
