2012-04-23, 21:19
W skrzyni 4r55e, w skrzyniach 5r55e banda nadbiegu jest używana zarówno w piątym jak i drugim biegu. Wyłączając overdrive otrzymujemy po prostu skrzynie 4r55e, unikamy więc wachlowania biegami pomiędzy 2 a 3 na przemian, dlatego m.in. należy wyłączyć OD podczas ciągnięcia przyczepy.
Dla ciekawskich:
The fifth gear of the 5R is achieved by overdriving first gear (for an extra gear between first and second), which means that the overdrive band is applied in second and fifth gears in the 5R (4th gear from the A4 became 5th in the 5R, 3rd became 4th, 2nd became 3rd, and a “new†2nd was born). What this means is that the 5R has the same lowest and highest gear ratio as the 4R, so it doesn’t change the low end pulling power or the fuel efficiency and speed of the high gear ratio…they are the same
Ostatnio zmieniony 2012-04-23, 21:22 przez
Damian, łącznie zmieniany 2 razy.
