Kółka same sie wyważają na bierząco.
Ciekawi to kogoś?
Więc,
W wielkim skrócie chodzi o to że wsypujemy do opony (bez żadnych odważników)kilka oz (uncji) kulek które to wyważają koło w trakcie jazdy.
Najlepiej użyć do tego kulek do ASG (Air Soft Gun).
W załączeniu tabelki z rozmiarami opon i wagą kulek.
Dla wyjątkowo zainteresowanych udostępnię artykuł w j. angielskim.
1 oz (uncja) = 28,35 g
1 g = 0,035 oz
Aby uprościć:
How it Works
The physics of how/why the free mass inside the tire automatically knows where to go is hard to conceptualize. The best way to understand why this works is to exaggerate the problem. Imagine there is a 5 lb weight fixed to one place on the tire. When you spin that tire to normal high way speeds, it will be so terribly out of balance that the tire would probably hope off the ground with every rotation. The axis of rotation is actually moved away from the center of the wheel toward this extra mass because it’s pulling the whole tire with it as it spins. The free moving balancing weights inside the tire are not affected the same way by these forces. First as you get up to speed, centripetal force will make the balancing weight stick to the inside of the tire. Then the force of the imbalanced weight on the tire will move this balancing weight away from the imbalance. When enough of the mass is opposite of the imbalance, the vibration disappears and the axis that the tire is rotating on returns back to the center.
To give you another example to explain why the balancing weight moves away from the imbalance and balances the system, think about what happens when you accelerate fast in a car. Anything that’s loose moves to the back of the vehicle. This same force is created on an imbalanced spinning tire. The imbalance is jerking the tire sending the free mass inside away from it and the centripital force holds it here.
DB!
Nemrod
